Dynamic check boxes expanding subset of checkboxes
I’m trying to create a set of dynamic checkboxes for a site. I have it working as long as you click the boxes in order. It will expand the first list under the first check box and move the rest of the content down on the page. The problem is that I can’t figure out how to set it up so that you could start with the second checkbox…
  • Item 1
  • Item 2
  • Item 3
Clicking Item 1 expands a subset of options and moves Items 2 and 3 down on the page.
Since I put in the amount to move by, I can’t figure out how to make them move dynamically.
Any help would be appreciated!
Hi there! It sounds like you’re building something similar to an accordion, where instead of headers you’re using checkboxes to expand and collapse content. If you haven’t already, I’d recommend trying out the tips from the accordion tutorial to see if that does the trick. If not, then would you mind posting your file so that we can take a look and better advise? Thanks!
