Dynamic panel doesn't move with its entire section
I’m trying to remake a prebuilt accordion widget. Could you explain to me why the plus icon that I added myself doesn’t move with its entire section?
File:
test-acc.rp (101.3 KB)
“Push widgets below” only affects widgets that are directly below some part of the widget being shown.
The simplest solution in you case it probably to:
  • add padding to the left of “pnl content” so part of it is above the “+” below.
You probably expected the fact that the “+” is in a larger group, part of which is below “pnl content” would imply the whole group should move. Nup. :-/
Thank you for clarifying, Shanemo. You’ve helped me a lot.
