The vertical scroll bar on my fixed height dynamic panel jumps to the left when I toggle an accordion with “Push/pull widgets below”. With multiple adaptive views, once jumping back to desktop, the panel with is set to the same size as the smaller mobile view. It doesn’t happen when I remove the page height to use a desktop vertical scroll bar, Only when I’m using the push/pull function within a dynamic panel where the page height is set for a mobile scroll bar.
Example-File.rp (143.9 KB)
Dynamic Panel Mobile Vertical scroll bar push pull bug
ewhitmire
#1
ewhitmire
#2
Also, when you jump back to the desktop view after using the push/pull in mobile, it sets the panel width to the width of the 1366 adaptive view panel width that was resized using the push pull.
