Dynamic Panels not moving with push widgets
I’m creating a form with lots of push widget actions, as different options appear or disappear depending on what you select. I’ve put everything into dynamic panels but in the attached file I’m getting an issue where the content appears but doesn’t push down the dynamic panel below it.
I’ve tried everything I can think of and it hasn’t worked, so please take a look at let me know where I’ve gone wrong!
In the preview, select the options in the dropdown lists that have actions attached and you’ll see the content appears but the “HTML” box doesn’t move.
Test.rp (175.3 KB)
I’ve moved the secondary message DP onto the pain page and out of the Promotional Messages Dropdown DP.
Testv2.rp (174.8 KB)
Awesome, thank you so much for your help!
