Edit shape attributes on event
Hello everyone,
is there any way to edit a shape attributes and properties when an event (let’s say OnClick) is fired?
What I want to do is to transform a rectangle into a circle but I can’t find any option to either change shape type or add corner radius values.
Thanks
Hi @Pandorave,
Try this:
  • Select your rectangle > Properties > Interaction Styles > Selected. Here you can set the desired corner radius.
  • Now add a case OnClick and make it toggle the value of selected (‘Set selected’ > This widget > set value to toggle).
Hope this works for you!
Cheers,
Rumturf
Thank you @Rumturf,
that’s certainly a solution, though I’d like to see a transition and Axure doesn’t have transitions for Interaction Styles.
Anyway, this is the only way I’m afraid.
Thanks again :slight_smile:
