@chutch15,
No, if you are using a local file, then it won’t show up in the Axure editor or the Preview mode in the browser. It would be a good feature request though.
Actually, the editor will not show any content for an inline frame widget, ever. You can use the generated HTML to see a local file in an inline frame.
If you want to use Preview to see/test with inline frames, then you need to post the content on a server. There are sites like Google Drive, Dropbox or Internet Archive which let you easily post content with URLs. If you need more security, work with your company’s IT to provide an intranet web server or consider Axure Enterprise.
By the way, you can use relative paths for your local files (and I recommend doing so) if you use the proper format. (I can’t recall if this was the case in 2016 when this thread started.) ./myfilename.ext
for files in the root folder, or ../myfilename
for files one folder up (or in other words, the same folder as your generated prototype folder), or just the filename for files within the same prototype folder.
