Export Image Coordinates
Is there a way to easily export image coordinates in Axure?
We turned over an .rp file to a vendor and it came back all whack. We’d like to be able to export a report that has the image coordinates to lessen mistakes.
Thanks
Hi jteason!
You can export the coordinates of an image in your project either by using the Word specification feature, which comes with the option to list the location and size of each widget, or you can do this dynamically in your Axure file by setting text on a widget to [[LVAR1.x]], [[LVAR1.y]], where LVAR1 is referencing the image widget. If you haven’t worked with local variables before, or the Word specification, here are a few articles that should help:
https://www.axure.com/support/reference/variables#local_variables
https://www.axure.com/support/reference/word-specification#the_"widget_tables"_tab
