External javascript graph
Is it possible to add JS graph like this one over here >https://mining-profit.com/api-bitcoin-chart< to my project?
I tried this script
javascript:$('head').append('<script src="https://mining-profit.com/js/mp-btc-chart.js"></script>'); void(0);
using OnPageLoad but it doesn’t work at all. I browsed whole forum but I wasn’t able to find topic that could help.
Pls, help :sweat:
Hi dvobecky!
While the use of JavaScript code goes outside the expertise of our help desk, you can add external code to your prototype using the Plugins feature on Axure Share:
https://www.axure.com/support/reference/axure-share-basics#plugins
It would be here that you would be able to add your JS graph code to the head, body, or to a specific dynamic panel in your project. Please note, however, that you will need to publish your project to Axure Share to utilize this feature.
What exactly does not work? Are there errors in the console? Is the request for the script successful?
I tried this out and got the javascript to declare successfully (<script src="https://mining-profit.com/js/mp-btc-chart.js"></script>). Using the example script at the bottom of https://mining-profit.com/api-bitcoin-chart I could get the headers to be drawn but not the chart itself. Maybe the chart needs a specific div name which can’t be assigned by Axure? (Or alternatively, I didn’t know how to point the draw() command to a specific Axure widget.) I think there was a generic “can’t draw” error for the last command: MiningProfitBTCChart.draw();
It worked!!! :slight_smile: Thanks a lot!
