Feature Request: Toggle effect for the set size
I have been prototyping for a long time now, and I know that it’s not just me who encounter this part. We hope you could add a toggle effect for the set size. This can make our prototyping ez. Well imagine the part where a button is set as a toggle effect. then all is well until you also need to adjust a background because the push widget ruined it all. So you did it and it works well. But once you toggle back the set size does not return to its previous value. And don’t tell me to use dynamic panels. Cause this is a push-pull widget scenario. Rapid prototypers can understand this kind of issue. I don’t want to use my long method which is set variable if else method. Hope you can understand thanks thanks.
