Filtering repeater with dynamic panel
I need to replace form field checkboxes with styled checkboxes for a repeater filter.
At the moment each checkbox has OnSelectedChange ‘Update Rows Set None where “[[true]]” in Repeater’ attached and checkboxes are assigned to groups.
Attaching similar functionality to the OnClick event of two state styled repeater does not work.
You have to make some condition logic with global Variable / local Variable if possible and put it to OnClick action.
Pseudo: like if OnClickVar == checked then…else OnClickVar == false then
Only that way you can mimic OnSelectChange
BR Karel
Hi toomanyairmiles,
I worked on some pattern before (custom checkboxes and filter).
Here is my file:
custom checkboxes.rp (615.6 KB)
Hope it will help!
Natalie
