Fixed header lightbox
I am trying to set a fixed header in a lightbox with a scrollable table.
My question: Where do I pin the header to? If I pin it to the browser as is suggested it does not comply with the dynamic location of the “lightbox”.
thanks
Place the header directly in your lightbox and place add dynamic panel for the content. On this you can set the scrollbars to “vertical as needed”. Heres an example.
modal.rp (52.2 KB)
Optionally you can add some logic to adjust the height to equal the window height for example.
thanks, works like a charm
