I have my fonts loaded correctly, yet nothing works.
Please help!
Hi VersaJ,
From the AxShare link you posted, it looks like the Source Sans Pro web font is correctly rendering on my end. Could you post your .rp file here so that I could take a closer look? Please also lmk the build of Axure RP 8 you’re running (e.g. 8.1.0.3381), the browser you’re using to view the prototype, and where exactly in your file the Source Sans Pro font is not rendering for you.
Hi Jane,
Thanks for getting back to me!
I’ve attached my .rp file. The version I’m using is 8.1.0.3379.
I’m trying to view the axshare link from my iPhone X using Safari.
US Foods Supplier v1.rp (124.4 KB)
Hi VersaJ,
Thanks for the .rp file! I see the issue now.
It looks like you’re using several different font weights for the Source Sans Pro web font in your file, but only the Regular font weight (400) has been defined in the CSS link.
To remedy the issue, you’ll want to select all the different font weights you used in your file on the Google Fonts site by switching over to the CUSTOMIZE tab:
Then, switch back to the EMBED tab to copy the updated CSS link:
Which you will then want to copy & paste into the Web Fonts tab of the Generate HTML dialog:
I’ve applied these changes to your file. Lmk if you have any questions.
US Foods Supplier v1_EDIT.rp (124.5 KB)
