Formatting specific text field (mask)
Hi everybody!
I need a help, please.
A text field with a format like this:
XXX.XXX.XXX-XX
But the two points and the “-” appears while is typing the numbers…Is that possible???
Thank you very much!
Hi @vannucci,
You have to add “.” and “-” to the text in the text field OnTextChange trigger when you have the right number of characters
See prototype below:
Text-fiel-mask.rp (45.4 KB)
Best,
My friend,
When I use delete to go back and clear the field, there is a lock on the “-” not deleting the previous numbers.
Can you help?
Hi @peixoto.rodrigo,
A tricky issue indeed :confused:
One have to change conditions to not trigger when “Back” key is pressed
Text-fiel-mask_V2.rp (46.4 KB)
Best,
Thanks so much! Perfect!
Thank you Pierre!!! Excellent!!!
