After it took about 10 years for bullet points to finally work in Axure, it’s about time that they are finally displayed correctly when a mix of text and bullet points is needed. At the moment, you have to create two elements for a left-justified arrangement of text and bullet points.
And when will it finally be possible to adjust all padding values at once? A simple lock function like for height and width should not be a big problem.
And the display for “distance” should also be further developed, other UX tools are miles ahead. For example, the display of identical distances between several objects would simplify the placement enormously.
These are all points that have been around for so long and where nothing has happened for years. It is simply annoying that some fancy features that nobody needs are implemented, but the basic functions are neglected.
