Get value of hint text
Hello!
I need to get a value of a hint text in a text field. How can I do it?
I need to assign value of hint to a label.
Thank you.
Hi Svetlana,
Hmm, it doesn’t look like hint text can be accessed by the Set Text widget, since the hint text isn’t actual widget text. To verify, what sort of setup are you using this for? Since hint text has to be defined manually in the Axure RP editor and does not change in the browser, would manually setting the text on your label in Axure RP work for your needs?
