HELP ! I need help printing a string in my repeater table in one dynamic panel state, based on a selection in another panel state
Hello!
I am a novice AXURE user and I need help!
I need help printing a string in my repeater table in one dynamic panel state, based on a selection in a droplist from another panel state.
I want my selection for 1 and 2 below
to print here
i want:
  • The numbers 1 & 2 to print under the rank column
  • What every the selection as for each droplist to pint int the weather phenomena column
  • 1 & 2 to print again in the score column
I have attached my file to this post, please help!kingtoolipadhelp11:6:18.rp (157.7 KB)
Hi kingj14,
You can do this with local variables, by creating an “Add Rows” interaction to the OnSelectionChange event to both droplists where you add the text on the “1” and “2” texts to the Ranking and Scoring columns and the selected option of the droplist to the Weather Phenomena column.
Here’s a screenshot to demonstrate this:
I’ve also made some tweaks to your file that should make this more clear. Lmk if you have any questions!
kingtoolipadhelp11_6_18_EDIT.rp (145.5 KB)
