Hi there, i’m prototyping a simple click through and want the page to remember the scroll position, there is this Maintain scroll position after click but i have no idea how to implement it, i’ve only been using axure for a day… Any help would be really appreciated…
Help! Need page to remember Scroll position
nkrisc
#2
Add a Hotspot widget. Give it a name. How about “ScrollTarget”. Add a global variable. Let’s call it “ScrollPosition”.
OnWindowScroll
Set value of ScrollPosition to: [[Window.scrollY]]
OnPageLoad
Move widget ScrollTarget to X:0, Y:[[ScrollPosition]]
Scroll to widget ScrollTarget
Jerry000
#4
Is there any way to do the same, but inside of scrolling dynamic panel? I do not have window to scroll, but panel.
Jane_Axure
#5
Hi Jerry000,
You can do this with the dynamic panel’s OnScroll event with [[widget.scrollY]]. So following nkrisc’s example:
- Add a hot spot widget inside the targeted state of your dynamic panel.
- Add a global variable, e.g. scrollposition.
- OnScroll of the dynamic panel, set value of scrollposition to [[This.scrollY]] where This is the dynamic panel.
- Add an additional Move To interaction to the OnScroll where you move the hot spot to (0, [[scrollposition]]).
I’ve added an example file to demonstrate this. Hope it helps!
SaveScrollinDP.rp (56.6 KB)
system
closed
#6
