I am having trouble with creating a menu that displays after the user exits the menu label. I have a mega menu that animates down/up and works perfect, but the hot spot for the menu is too small. Every time I move off the label, the menu disappears. I need help making a larger area for the mega menu to display even if the user enters the cursor over the menu itself.
So why am I doing it this way. I need to show the menu unveiling as apposed to animating down with the background, so I need to have the background animate down and then have the menu links fade in. Both are on separate groups and that is why I can’t use the normal “treat as flyout”.
I have attached a simple test filemenu_test.rp (44.9 KB)
Thanks for any help you can provide.
-Steve
