Help! Validation related
advanced-prototyping
#1
Hello, i just started exploring more about AXURE, especially Axure 8, i’m having trouble, my lecture ask me to make a validation for text field (type as file, so we must upload a file on it), turns out my lecture doesn’t know the way either.
I’m a bit confused on the conditional setting. I’ve been looking through the internet how to make that validation possible but haven’t been able to find what I need.
Can someone help me on this? Thanks.
#2
@inggriedkurniawan if i don’t understand wrongly, you want to upload a file, and validate against the filename to check if the file is an image (with .jpg / .png / etc.) or some other similar validations?
If yes, then in my POV, i think it might be a bug in Axure RP 8
i created a file type text field, and attach 2 events on it:
  • OnLostFocus()
  • OnTextChange()
    And both of them did the same thing: display the content of the text field in a box
Surprisingly, the OnTextChange() event failed to capture the text change, which is a bug in my opinion, because the content is indeed changed as proved by OnLostFocus() event
Untitled.rp (48.1 KB)
As a workaround, i would suggest you try using OnLostFocus() event, although it requires a manual click after you select the file
