Help with Checkboxes!
Hi!:slight_smile:
I am new to Axure, I am trying to get a check box to toggle (basically get ticked) when ever a user clicks on a certain text box.
So if a user clicks on the text box which says ‘single’ it will tick the check box! How do I do this?
Thank you!
@dynasto,
Welcome to Axure! There are many ways to achieve this, depending on what you are trying to do, exactly.
Here are a few examples of checkboxes.
Custom Checkboxes.rp (121.2 KB)
If you use the standard “Forms” checkbox widget, then clicking on the actual box or the text will toggle its selection state:
If you are building a custom checkbox, or are trying to control it remotely using another widget, have a look at the interaction code for each of the widgets in this example .rp fie.
