We’ve added a ‘slew’ of new hide/show options to help you make building common design patterns like flyout menus, accordions, and lightboxes much simpler!
Show
[ul]
[li]bring to front: brings the widget(s) you are showing to the front (z-index)[/li][li]treat as lightbox: will display a customizable background around the widgets(s) being shown, widgets will be hidden when clicking outside of the shown widget(s). Commonly used with Pin to Browser (middle, center).[/li][li]treat as flyout: will create an invisible boundary in between widgets where your cursor can travel without hiding the widget. Perfect for making tooltips and flyout menus.[/li][/ul]
Show/Hide
[ul]
[li]push/pull widgets: moves widgets below the widget(s) being shown up and down as they are shown and hidden. Prevents from needing to use “OnMove” events to control accordion menus and collapsable content. More info[/li][/ul]
See it live
show-hide-options.rp (53.5 KB)
