Hello. I added text field and selected date type for that field. At the end I added hint text, but it’s not visible. instead I have text for date format mm/dd/yyyy as a hint text. Is there any solution for this?
Hint not visible on date field
AppleStrudel
#2
Hello! I had the same issue and solved it by changing the text field type from “Number” to “Text”. Another option would be for your hints to be numerical. So the logic is: the hint needs to be in the same format as the text field “Input type”.
I hope this helps!
