How can I change the appearance of single rows in a repeater?
Hi there,
I’m relatively new with Axure and this might seem like a simple problem, but I don’t know how to solve it.
I’ve created a simple table with the repeater widget. Now, I’d like to add a text field, but only in a few rows. It should not appear in every row of the repeater.
I’ve already tried to solve this by adding a condition on the case OnItemLoad, but it didn’t really work.
Can somebody help me? How do you change the appearance of single rows while the data of repeater is being loaded?
Regards
Check the index on itemLoad, with a condition specifying which index # (row #). You can use a selected style or if you need something completely different, put the row in a dynamic panel and switch the state for the row# you want using the method above.
If value [[item.index]] = 2 for example
Thank you so much! Now it works :slight_smile:
