Hey. We were on Axure Pro but upgraded and now have Team…but how do I start Using it? How do I change over from Pro. I have a Team Key but not sure what to do with it.
Can someone please help?
Thanks
Thanks
If someone gave you a Team Project ID (the “key”) then you can join the Team Project in Axure by going to the menu, Team > Get and Open Team Project… and pasting it in the Project ID field. You might need to know if the ID is on Axure Share, Axure Enterprise, or on an SVN server. Whomever gave you the key should know. Likely, if it is a 6-character key, using the Project ID will work. If it is longer, try the SVN tab and the “Team Directory” field.
You can learn more about using Team Projects here:
https://www.axure.com/support/reference/team-projects
