How to add Checkbox or Input field to table cell?
I would like to know how do I add Checkbox or Input field, dropdown list to table cell ?
Thank you,
Thong
I’ve not got Axure 9, but in v8 the table widget isn’t very flexible and you can only put text inside the cells. If you want to put other objects inside cells and present them as a table, you’re better off using a repeater.
As an aside, the table widget is really next to useless compared to using a repeater in pretty much all contexts. I’m a bit mystified as to why Axure still have it.
Thank you for your reply, JonB
I will give Repeater a try.
