How to exclude widgets from Push/Pull
Hey,
I am trying to do some flow with various On/Off switches, each showing more info under it when enabled. I am now moving other widgets down with push/pull widgets under option.
the thing is, I have Confirm buttons on the bottom of the site with a lot of white space above them.
Is there a way to exclude them from push/pull so they don’t travel away?
Thanks
You could put the widgets you want to move inside of a dynamic panel, and leave the widgets you don’t want to move outside of the dynamic panel. The push/pull would only impact those items inside the DP.
push-pull with DP.rp (53.4 KB)
@UXProtoTyper Oh thank you! that is exactly what I needed. Much appreciated
