How to show a folder and open panel on a relative spot
Sorry for the confusing topic title.
Basically I have a table set to hidden. When I click a button, I want to show the table.
However, the button is in the middle of a lengthy scrolling page.
Which partially hides the table when the button is clicked.
I tried converting the table into a dynamic panel and pin it to top.
It only partially works, because the button is not clickable when the table intersects with the button.
Hi arjay,
Could you post your RP file here so that I could take a closer look? That’ll be the fastest route for me to find you a solution/workaround for the issue. Thanks!
Thanks for the comment. I eventually was able to figure it this out thanks.
