I want to push the widget to the left from the right
I can push out the widget to the right by using push/pull options to the right.
however this time, I want to push the widget to the left … but I can’t it…
is it not possible? any idea?..
■–>□ push ok.
□<–■ no???
The push/pull widgets feature only supports widgets that are completely below or completely to the right. If you want to affect widgets that are to the left or above, you need to move them directly. If you want to move all widgets that are to the left of your initiating widget, I recommend grouping them all or putting them all into a dynamic panel and moving that. For instance, in the OnShow event you could have something like, Move MyLeftGroup by [[This.width]] and in the OnHide, Move MyLeftGroup by [[-This.width]]. Or, you could set up a “chain reaction” in which you only move one widget immediately to the left of your target, then that widget could move a widget immediately to its left with the OnMove event: Move WidgetName with this and so forth.
