Image upload, remove and replace
Here’s what I would like to do:
[ul]
[li]On click upload pic one of the three possible pics
[/li][li]Upload it to the first imagebox
[/li][li]Do the same for the other 2 remaining
[/li][/ul]
So far so good. But then comes the tricky part:
I want all photos to move along with the one that is deleted using the trash icons (no succes till now)
and last but not least I would like to have the images switch position either by click or drag&drop
I would be most grateful if there’s anyone who could help me out here and take a look at my file
fileupload.rp (3.03 MB)
Cool file, actually deleting the photos shouldn’t be too difficult from what you already have. I just add a new concept from here, Function/Functions in Interactions (Triggering ‘Custom Events’ on Widgets, Trigger, Triggers, Actions Macro/Action Macros).
Use a Dynamic Panel OnMove to “move3to2” and a similar “move2to1”. This way when deleting 2 you just move “move3to2” by 0,0. When deleting 1 you first move “move2to1” then move “move3to2”. (Make sure to use two different Move Actions otherwise you might accidentally move 3 to 2 first and then move 2 to 1 which would mean 3 moved all the way to 1.)
RP File: FileUploadWithDelete.rp (3.03 MB)
*Note: I added some OnPageLoad Actions to show default photos to make this easier to test. You can easily take those out when you are done testing.
Hi Ian,
So that does the trick :slight_smile:
Pretty neat! I gues a drag & drop simulation would also work using the same principal?
Thanks so much!
Marc
This is great, thanks to both of you for sharing.
