Images in Repeaters Behaving Strangely
I have a document using repeaters with images that are set in the data columns.
Consistently, if I fill in one image for all rows in the repeater, none of them load.
For example:
If my repeater has 4 rows and I’ve set the images in three of them, it works fine. If I set the image for the fourth row, the images don’t load.
I’m completely at a loss here. This behavior makes no sense.
Hmm how odd! I’ve tested in a new file on our end and it looks like with a fresh repeater with an image widget added, the images added in the dataset show for all rows. Are you seeing this in RP 9 on Windows or a Mac? If you can reproduce it from scratch in a new file, would you mind listing the steps? If it seems to be specific to one file, then would you mind posting a sample file with the repeater so that we can take a look? If the file contains sensitive information and you’d like to share it privately, then we can also receive it via email at support@axure.com and work with you one on one via email to diagnose the issue. Thank you!
Thank you very much for the quick reply. I’ve sent the file to support@axure.com.
