Hello
Someone in my team created a wireframe with Axure 10. We only have a licence for Axure 9.
Do you know a way to save the project as Axure 9 or import it somehow?
thanks
Hello
thanks
Axure versions are backwards-compatible only (newer will open older), not forward-compatible.
You might be able to cut & paste widgets from 10 to 9 (using the right-click option to “Paste Special > Paste including locked widgets” ; or Shift-Ctrl-Alt-V keyboard shortcut.)
If that doesn’t work, you could try sending a quick email to support@axure.com with your file attached. They might be able to do a one-time conversion for you.
