Hello,
I have set up a cascade of actions based on a repeater on load event. The actions result in a widget being shown, and starting a state change event which cycles through two states using a short timer to flash the widget on/off.
This all works great when the page loads. The problem is, when I start applying filters to the repeater, the icons stop flashing. I don’t know understand why this is.
I think I understand how the repeater works, and my understanding is that it re-loads the items when the filter is applied. So, shouldn’t that trigger the same event chain and end up with the same results (i.e. flashing widgets).
RP file attached. Happy to answer any questions or provide more details. Trying to keep things brief… the widgets in question are alert icons which are dynamic panels called “WarningAlert” and “CriticalAlert” inside all of the “gauge” style masters (i.e. BP master, TEMP master, etc.)
Project_210403_1.rp (618.0 KB)
