Interaction panes
The Interaction panel isn’t displayed even though it is selected in the menu : View > panes > interaction.
Do you have an idea where it is hiding?
Thanks !
Top left, there’s three tabs in the pane - Style, Interactions and Notes. These will only display when you have a page or widget selected.
Hi sylvia9!
If the Interactions pane is still not visible, you can try going to View > Reset View. This should reset all of the panes into their default positions in the application!
Thank you ! It works !
