Is it possible to change the repeater from vertical to horizontal?
I would like to know if it is possible to have the repeated elements horizontally instead of vertically.
Thanks in advance :rolleyes:
Hello,
you can change the order like that:
  1. double click repeater widget
  2. select tab Repeater Formatting in page properties pane
  3. choose layout (vertical / horizontal)
Regards,
Ben
I wanted to stack the repeater elements and view the rows as columns. When I switched the formatting to horizontal am only seeing the first row (see attached) what am I doing wrong?
