Is raised event removed from Ax10?
Hi guys,
I’ve been using Raised Event in master alot in Axure 9. Just tried Ax10 recently but I cant find it under Component action list. Is it removed or moved to somewhere?
Update:
I’ve found out that maybe it is a bug (Im using Ax10 on Windows 11)
When I right click on a normal widget can convert it to Component, the Raised Event action is not there.
But when I create new blank Component and add a widget in it, the Raised Event is there again.
It looks like this was a bug on some recent builds of RP 10, but this should be fixed on our latest build, build 3865! You can download the update from our website at axure.com/update or via the updater in RP (Help > Check for Updates).
Thank you, the bug is fixed in the new update!
