Is there any way to reset connector points to their original locations?
Hello, I’m creating a workflow diagram (status flow) and I moved a few connectors on a single shape, and created some additional points, and duplicated this shape across my entire flow diagram. Is there any way to reset the points to the original four locations (top, bottom, left, right), and remove the additional ones I added?
Hi BasicBrunch!
I wanted to let you know that there is no current feature that automatically resets connector points to their original locations. To set the points on your connector to the four original point locations, you will need to drag and adjust the current connector points to match these locations, and then delete the excess connector points. I can see how a feature that automatically resets connector points would be beneficial in your use case, so I’ll be filing a feature request with our teams regarding this functionality on your behalf.
Thank you Chelsea! Your response is greatly appreciated.
