Issue with repeater filter
I tried to filter the repeater using a dynamic value variable. For example, onClick on button, it will filter by (ID < (dataCount-5)). But then, the whole repeater view went blank. Below is the attached exaxmple file.
repeater filter.rp (52.1 KB)
If I understand your problem statement correctly, you want to end up with a filtered list decided dynamically.
Change from TargetItem to Item and your disappearing repeater issue will be solved
[[TargetItem.Column0 > (OnLoadVariable-5)]]
I tried that too but it didn’t work at first. Then retyping the condition made it worked.
Thanks
