Keep rows marked between pages
I have a repeater with custom check boxes.
  1. If a user checks a couple of the items
  2. goes to another page
  3. comes back
  4. I want the previously checked, check boxes to be checked.
I am currently marking and unmarking rows. But I don’t know if rows stay marked between pages or how to check if a row is marked.
As I am aware of only way to pass variables across pages is using global variables
Karel
Reading elsewhere, this seems to be the case. This makes me sad, as the point of using a repeater and marking/unmarking would be partly to avoid creating loads of manual variables etc.
I thought of adding, substracting to a string and then maybe using some crazy string operations to split out the values…but don’t think that would work / be possible.
Might have to resort to a load of variables.
Hi @richardstelmach,
Maybe something like that:
Checklist-save.rp (61.2 KB)
1-Concatenate an ID (1, 2, 3, …) on a variable when the checkbox is checked (OnSelect, [[Var]]ID
2-Remove it when you you unckeck it (OnUnselect, Var.replace(ID,’’))
3-Read the value of the Variable and check if you need to ckeck the item on the repeater (OnItemLoad, if Var contains ID => Set select)
Hope it will be useful,
Best
PS: with it you only need one variable, and it works if you don’t have too many list item (need one different ID for each item: 1, 2, … a, b, … *, %, @ )
Thats very clever just to concat variable and then pass it to one string. Well done. Have to learn this cause it could be very handy when select/unselect table value / with repeater and passing it to another page.
This works a dream:
  • add to global variable
  • replace in variable (to remove)
  • check if variable ‘contains’
Pierre’s solution is great.
