Hi folks,
It seems I’m experiencing a bug with Ax 7.0.3142. Steps to reproduce:
- Place widget on canvas (make sure it’s NOT square…i.e., a rectangle will do it)
- Note the Location in the Style tab of the Widget Properties and Style pane.
- Rotate the object
The coordinates reported in the Location and Style tooltip are correct, but the ones reported in Properties and Styles pane are not updated, so if you move the object, these will continually be incorrect.
