Low Fidelity Settings
Hi
So in previous versions of Axure, when you changed to low fidelity, your prototype / wires simply change to black and white without changing the font. I am not a fan of the sketchy font as it screws up all of my layouts.
Is there anyway to fix the low fidelity settings so that it does NOT change the font you use to that sketchy one?
The simplest solution, in Axure 9 at least, is to use font mappings to change Axure Handwriting into a font of your choice.
