Marquee: Rotate 8 images horizontally defined in onLoad event
Hi Guys,
I have about 8 images with me and I want to scroll them horizontally when the page Loads, i.e. onLoad event.
Please guide me.
Regards,
Apurvo
Maybe this will help?
https://www.axure.com/support/training/rotating-carousel-banner-tutorial
Thanks for your revert @Emgee, but I have different requirement.
In the attached rp file, I have 8 images and all the 8 images are visible. Now I want to automatically rotate them from left to right.
Is this possible?
Regards,
Apurvo
marquee.rp (56.5 KB)
Hi @apurvo,
do you have a live example of what you want to achieve?
Because on you first post you want to: [quote=“apurvo, post:1, topic:54134”]
[/quote]
and in your second to:[quote=“apurvo, post:3, topic:54134”]
[/quote]
Thanks,
Hi @PierreJ,
As of now, I do not have a live example.
But, to make things for clear this image has five blocks<img src="//axure-discourse.s3.amazonaws.com/original/3X/6/9/693a6fef8e993a586e5385c5fef7d42167093e0c.png" width=“690”.
height=“148”>
Now, on the image it shows 8 on the left and 12 on the right. Now on the page load, I want to define a case, which should make the bar scroll horizontally from left to right, which means after 1-2 seconds, 9 would be at the extreme left and 8 would be at the extreme right. Similarly, after 1-2 seconds again, 10 would be at the extreme left, 9 would be at the extreme right. This bar would continuously keep on scrolling from left to right.
Please let me know we we on the same page what I am trying to achieve? And, is this interaction feasible to replicate in Axure RP?
Regards,
Apurvo
Here look what @jlhelmers did on this post:
Using the interaction OnPageLoad and not OnClick on the button should solve your issue:
Bar_Scroll (2) - On load.rp (124.4 KB)
Best,
Thanks @PierreJ, this solves my problem :slight_smile:
Regards,
Apurvo
