Menu Interaction Styles - some items not selectable — HELP!
I know I’m an Azure RP 8 ‘newbie,’ but I’m stuck on something that I thought would be simple.
I’d like to place an line under selected main menu items. While Line Color and Line Width are selectable, I can’t access Line Style or Border Visibility.
What do I have set wrong?
Hello and welcome!
What’s the object that you’re applying the menu style to? Is it a shape, table cell, or something else? Can you upload a file or screenshots so the we can see what’s already applied?
Hi 28
I was attempting to apply an underline to a ‘Classic Menu - Horizontal’ widget.
Did you ever resolve this? I didn’t see a notification that you replied. :frowning:
Hi Figment,
As you’ve found, Line Style and Border Visibility are not available to style with the Class Menu widgets. If you wanted to apply an underline style to a menu item, however, you can select the “Underline” option (above Font Color).
Hi 28,
For some reason my post going back a couple of weeks never went through (ether gremlins).
As Jane notes, the Classic Menu doesn’t allow line/border adjustments.
Thanks,
Fig
