I’m trying to use the Google font Merriweather in RP9 but it won’t render in the editor. When I select Merriweather as a font, Axure keeps resetting it to Helvetica. The font worked fine in RP8. I’m on MacOS High Sierra.
Merriweather font will not render in editor
Hi mike1366!
Hmm, I’ve tested out using Merriweather’s regular and bold font weights on High Sierra, but I haven’t been able to reproduce this issue just yet. As a first troubleshooting step, please confirm that you’re running the latest build for Axure RP 9. You can check on this by navigating to “Help > Check for Updates” in Axure RP 9. If this behavior persists with the latest build, could you send along a sample file where you’re seeing this issue? If you would prefer to keep your project private, you can email us at support@axure.com and send in the file there instead. Thank you!
