Unfortunately I’m stuck on RP9 and can’t open your file (Axure, please give me a perpetual license option so I can upgrade!), but if I had to guess, you probably need to make sure your play/pause actions are targeting the right player.
In my code in the original post, there’s this part: append("<audio controls id='player'>
where the id='player' part is how you target the sound. So if you have multiple sounds, you probably want to change that for each one to something like id='sound1', etc.
And make sure you’re appending each player to a dynamic panel with a unique name, otherwise they’ll all be the same.
No problem. I can’t tell what the issue is from what you posted, but here’s an rp file with two embedded sound files, both looped, that can play/pause independently:
You hit the nail on the head. I sincerely appreciate your assistance - I’ve noticed that the problem I experienced was part due to syntax, and part to Safari not performing consistently - chrome seemed to deliver more consistent results with both. With your permission I’d like to refer to you as Sifu Ishillman.
Thanks for helping Axure do things it was perhaps not designed to do… yet, we’re almost in 2023, and I hope Axure product managers pay greater attention to the conversations taking place in this forum and understand that we demand an experience prototyping platform that goes much further… cannot help but notice how Adobe and Figma are joining forces to build the next big thing…
Hello @ProtoAlex
After a couple of years I now find myself needing a bit of help on the multiple sound tip above. Sorry to be a clod on this but I’m not clear on where all the base64 sound content should reside. Is it one audioPlayer file with all the encoded sound content, and with each sound separated by “<audio controls id=‘playSound1’><source src=‘data:audio/mp3;base64,ENCODED_Sound1’ type=‘audio/mp3’></audio>” or something different?
I’m also a bit lost on how the global variable would work here. I can certainly create one but is its default data the audioplayer data? Thank you so much in advance. I’m still using v9.0
@uiguyjohn each base64-encoded audio clip gets its own player (<audio>...</audio>), which you’re appending to an Axure widget (e.g., a dynamic panel or just a rectangle) named “audioPlayer” in ProtoAlex’s example (but you can call it whatever you want). The actual audio data goes in the <source> tag where you’ve got ENCODED_Sound1.
ProtoAlex is suggesting storing the audio player code (the <audio> tags and everything between them) in a global variable in case you’re going to be reusing the sound files across multiple pages. If you’re only using it in one place, no need to use a global variable.
My example RP file here was built in v9 if it helps.
Awesome, thank you so much @Ishillman, this is exactly what I need to do the job. I was close as I set it up similarity but missed a minor detail. All good now. Thanks again
Embedding audio in Axure has always been a bit of a workaround, so it’s great to see a clear breakdown of the process.
One thing I’ve found that helps - especially if you’re pulling files from different sources - is to make sure the metadata and file names are super clean before you start the embedding process. If the tags are messy, it sometimes messes with the player’s display or loading. I usually run my clips through https://editmp3tags.com/ first just to strip out any weird characters or unnecessary info. It keeps the file size down and the RP file a bit more organized.
This usually happens if there is an ID conflict in the appended HTML. Double-check that each audio element has a completely unique ID (like ‘player1’ and ‘player2’) instead of reusing the same one. If the IDs are identical, the JavaScript call will only ever trigger the first instance it finds in the DOM.
