Hi guys,
I am trying to solve the following:
In my klickdummy, I want to select widgets in a repeater when I hold the mouse down and drag the cursor across them. When I release the mouse button, widgets should not be marked anymore on mouse enter.
Please see in the attached file how I attempted to that. It worked poorly once, but after I had to redo my solution I am running into a bug where upon MouseDown I get the graphics that you get when several conditions apply at once.
drag across widgets to select them.rp (101.3 KB)
Another feature that I did not find a good solution for is in the third column (type 3). Here the user should only be able to select 4 month as a block starting from the first selected month. If type 1 or 2 is selected for one of those month, they should be unselected while the 4 month for type 3 are selected.
Thank you for your advice!
