Move a repeater to cursor position on MouseEnter
Hello
I would like to use my repeater as a tooltip. Depending on where I mouseover, I want the repeater to filter to match the object I’m hovering - this works - and then I want it to move to where I’m hovering - this doesn’t.
I’m hovering over a chart, so data points are not a part of the repeater. Only the tooltip.
I just seem to cannot get the mouse coordinates right.
I will be very grateful if somebody could take a look at the attached rp file and tell me what I’m doing wrong.
You can see different tries on different data points. I was just experimenting.
Thank you.
move_repeater.rp (72.4 KB)
You can’t move a widget that’s inside of a repeater to a location outside of it. You can wrap the entire repeater in a dynamic panel and move that to your cursor coordinates.
Thank you
This works :slight_smile:
