Moving object by Shift + Arrow key
In Axure (8), the feature I like a lot is jumping to a grid value, when moving an object by Shift + Arrow key.
For example: Object being at X=213 would jump to X=210 (Grid being set to 10).
Axure 9 does not seem to work that way. It jumps from X=213 to X=203.
Is that a change or just a feature not yet covered?
It sounds like you’ve got the “Snap to Grid” setting turned on in RP 8. You can turn the same feature on in RP 9 to get the same behavior. Go to “View > Rulers, Grid, and Guides > Snap to Grid” to turn it on.
Yes, that is right. I do not know how did I miss this.
Thanks, Rachel!
Tadej
