I am not sure that I understood complacently the expected behavior, but -
- I don’t need the grouping on the rows.
- in the first row, there is no need to have the buttons in a dynamic panel, and also the hot spots are redundant.
- use “Onclick” to toggle if the tab is selected or not selected.
- use “OnSelected” and “OnUnSelected” to create the interaction that you want.
- I would advise you to change the style of the buttons when they are selected. Look for the “Interaction Styles” in the properties tab.
Here is a beginng:
troubleshoot2.rp (803.2 KB)
Regarding the hiding of the panels - I didn’t understand what exactly you want, but you can do something like this: If, for example, click on “diamond” is enough to open "ring’, but in order to close “ring” you need that not only “diamond” will be un-selected, but also “Metal” to be un-selected, that you need to add a condition to the action “OnUnselected” on “diamond” that asks if the status of Selected for Metal is false, and only if true, close “Ring”.
