Multiple validations in forms
When pressing a submit button I need to show the correct validations in a form. On top of that, there are other conditions on the button “on click”
(if - Else)
I found this widget [https://bit.ly/2EMEcmG] which allows different validations according to this tutorial [https://www.youtube.com/watch?v=ZuWRzTnzQNc] but -
A. Nothing happens when trying to add an “On click” interaction.
B. It doesn’t work if it is applied in a dynamic panel’s state, I guess since the script is linked to “On load” State.
Can I fix this?
Why is the “On click”! interaction not working?
Is there a way that I can place it in a state and not on the front of the page?
IF NOT - Is there any other way to validate different fields with different alerts if the submit button if it is filled with other interactions?
TNX
Can you share your RP file? Hard to help you find what’s wrong if we can’t see what you did :slight_smile:
