Need help with counter; counting only when clicks matches the value of exponent of 2
Hi guys!
I am new to Axure and I am using this platform to create a project for a study. Here, I have two circles( 1 black and the other white) that each time that you click will count 1 on each square. However, in the middle I have a box that counts the total points earned.
The fun part is that I want to create a function that says that after 2 times click on the white circle then add 1 to totalpoints and if after 6 clicks on the white circle it will count another point that will go to total points.
I want to be able to say if bResponses == 2 then do totalPoints + 1 and if bResponses == 6 then do totalPoints + 1.
the black circle (aResponses) its only adding points to the totalpoints for every click.
I hope I am making myself clear.
Thanks for your help!
Project.rp (48.8 KB)
here you go (assuming I got the task right)
Project_fixed.rp (48.5 KB)
update: and just in case you wanted to count only every other click for the while circle here is that version too
Project_fixed1.rp (48.5 KB)
Thanks so much!!
That works perfectly!
